Old 04-11-2018, 01:16 AM
stephen low's Avatar
stephen low stephen low is offline
G'day Brewy
My G-Force has S2 front and XJ6 rear.
To-date I've swapped out the front top arms for fully adjustable jobbies for greater and easier adjustability.
The std xj6 rear is solid skinny inboard discs and twin shocker set up with a lousy handbrake system.
The common swap and which I am doing is use of XJ8 - X308 rear, same hubs and mounting but with outboard big vented discs, larger calipers and an effective handbrake.
I've also gone from very basic std gas monroe shockers and fixed coilover to double adjustable Konis with adjustable coilover, with single shocks to the back.
Like LoBelly said the original stuff worked in my car, well maybe not the handbrake, but to vastly lift performance what I have and am doing is typical performance enhancement better dialling in performance.
Not cheap though the Koni-Eibach springs have cost me nearly $5K but were set up and installed by a suspension expert.
So the standard stuff will get you going without concern.
Steve
slowy
