Old 04-11-2018, 05:40 AM
1795's Avatar
1795 1795 is offline
If it is a Hurst linkage, I would concur with Dan and suggest ash you use the steel bushings and spring clips instead of the stock nylon bushings. The nylon ones can wear out and then the linkage gets sloppy and can cause difficulties with gear engagement.
Jim
