Old 04-13-2018, 01:23 PM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
Originally Posted by MAStuart View Post
Garlock G10DU washers.
Attachment 31718
My parts came in . I wasn't sure what to expect. These are made just like the bushing that go into the A arms. These are made of tin coated steel and on one side the have a special coating that includes PTFE. I was surprised to see it is coated on one side and has a hole for a pin to keep it from rotating. The dark side is the coated side.
My question is did original uprights have pins on the thrust surfaces for these washers ? Or are these G10DU different from what it should take?
No pins. The 1960s ones look a little different color wise, probably more environmentally friendly coatings these days I guess, but they work the same.
Dan Case
