  #48 (permalink)
Old 04-15-2018, 04:28 PM
cycleguy55's Avatar
Originally Posted by Tom Wells View Post
Brian,
My memory may have it a bit inaccurately but a Holley throttle body is somewhere around 1-1/2" shorter than a carburetor.
The MPFI throttle body measures 2" from manifold flange to the air cleaner flange. The newer "all-in-one" EFI units measure from 3" to 3-1/4", closer to a carb's height.
With the MPFI, the injectors are in the manifold vs in the throttle body for the all-in-one units.
Overall height also depends on the type of elbow (e.g., round or oval-shaped) you choose.
Hope this helps,
Tom
While a 2" high throttle body is better than the standard height, I'd rather use that for a more gently curving inlet elbow and/or a raised carb pad. YMMV
Brian
