Old 04-17-2018, 07:48 AM
blykins blykins is offline
If compression allows, I always grind a lot of advance into my street cams. The throttle response and snap is very much noticeable.
Most of my 110 LSA cams end up on a 104 ICL. My 106 and 108 LSA cams will usually end up at either 102 or 100 ICL, if the piston/valve clearance and the compression ratio will play nice with each other.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
