Old 04-17-2018, 11:28 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
That lower trailing arm is so the rear doesn't twist itself up under load.
I can't see how you can heim joint both ends of the lower arm, unless you add an upper trailing arm as well.
Gary
