  #26 (permalink)
Old 04-22-2018, 11:51 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Hello Paul,
Your PCV valve fitted to the passenger valve cover is a restriction to blowby gas when the engine produces more blowby under load.
Pull the valve out, and blow through it from the valve cover end, then compare that to a hose of the same diameter.
Your system appears to vent the engine to a catch can, which is vented to the atmosphere with a K&N filter, which is a very common way of allowing the crankcase to be vented.
Because it is vented to atmosphere, it is not classed as a PCV system, since the engine is not consuming the crankcase gases.
So, in a nutshell, there should be free flowing hoses without PCV valves fitted in your system.
Hope this helps.
Gary
