Old 04-23-2018, 12:02 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Good to hear you are making progress Paul.
I would replace the needle and seats with the same type, then reset the float levels to 10mm.
Can you list your carb tune settings, choke, main jet, emulsion tube, air corrector, idle jet, pump jet, pump exhaust?
Or are they as factory set for a 44 IDF?
Gary
