Old 05-09-2018, 02:52 PM
Grey 65's Avatar
Grey 65 Grey 65 is offline
Cobra Make, Engine: BDR #888, Keith Craft 408
I would try 25psi at all (4) corners as a starting point.
You also might want to set your rake. I would recommend +0.50" rear. Meaning measure the two main rails at the front and the rear of them. The bottom of the rear end of the rail should be about 0.50" higher than the bottom at the front end of the rail. If it is much higher like +1.00" or more this will make your car prone to snap oversteer...
Kevin......
It isn't how fast your car can go
It is how fast your car can change direction
Home of Fake Snake Racing
