Old 05-15-2018, 08:28 AM
Apex_speed's Avatar
Apex_speed Apex_speed is offline
Cobra Make, Engine: Superformance Mk3 with Roush 427R
Originally Posted by bingo2 View Post
You can use a Street Tee (Google if you are not familiar with them) of the appropriate size, probably 3/8 NPT.
Yes. Mine is a bit larger so I was just going to use a tee that was gauge specific and flanged on either end as it is a rubber hose. Many of the gauge adaptors I have seen for smaller houses are widened in the point where the adaptor threads in so it doesn't create a restriction. I would probably try to find one of those.
Anyway, I take it that it is OK to tap into the bypass line and that the coolant flow there is constant and representative of engine temp? At least close enough for my dash gauge?
Thanks.
