Old 05-16-2018, 06:35 AM
bingo2's Avatar
bingo2 bingo2 is offline
Cobra Make, Engine: RUCC, SB 331 Stroker
No heater. The CTS is located in the passenger side port where the heater valve would be located and the sender for the analog temperature gauge is in the driver side port. I originally had them installed opposite of their current location but, I changed to more efficiently route the wiring; readings were identical from either location. If I did have a heater, I would try the tee in the driver side port and if it didn't function to my satisfaction I would drill and tap another port as others have suggested.
