Old 05-16-2018, 04:23 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Is there no room in the front water crossover to add a temp sender?
I would drill a hole, tap it 1/8 npt, and fit the sender.
That way you can see the engine warming up on all gauges.
Adding a sender after the thermostat, the gauge will barely work at all, then rise up, showing the thermostat operation.
Unless you want to see it that way.
Gary
