Old 05-16-2018, 07:53 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by cycleguy55 View Post
BTW, the fitting on the intake manifold is the hot coolant to the heater, and the heater return goes to the water pump.
If you must use a heater hose, this is correct.
Using the return hose would be like placing it in the bottom hose, as the return from the radiator.
