Thread: Fuel gauge
Old 05-18-2018, 06:58 AM
RockBit's Avatar
RockBit RockBit is offline
Cobra Make, Engine: ERA #812 427/482 FE
When you replaced the sending unit did you adjust the range of motion of the float for your tank?
If you disconnect the sending unit and ground the disconnected wire going to the gauge, your gauge should go to full. If it does, your gauge is ok. If not, the gauge is bad.
Chris
