Thread: Hi.
  #83 (permalink)
Old 05-24-2018, 09:37 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Gaz64 View Post
Yes, it is ok, but not as accurate as the positive stop method.
Originally Posted by t walgamuth View Post
I took a better look at the dial indicator today and he was reading it off a pushrod. Looked to be pretty accurate I should think.
The positive stop method is to find "True TDC", the best way to find "True TDC". A dial indicator is ok, but the piston sits still for a few degrees before and after TDC.
Readings off a pushrod would have been while reading the camshaft.
Have you got some photos of the build, especially the camshaft timing setup?
Gary
