Old 05-25-2018, 03:22 PM
crendonman427sc's Avatar
crendonman427sc crendonman427sc is offline
Cobra Make, Engine: ERA 289FIA - 1964 - 289 HIPO
Originally Posted by fastd View Post
crendonman,
congrats.
I like the FIA better also.
I really love my t56 6 speed. not sure what rear gear you plan on running but 6 speed civilizes cruising so much that I think it's worth it.
i'm in the middle of adding the holley sniper efi with dual sync distributor. maybe figure out if you can get the fuel pump in the tank.
one of the biggest issues that hound me is heat in the carb and starter and quality of gas these days. I think the efi should solve 2 of these 3 issues.
what dash layout did you choose?
aluminum heads on your 302?
good luck.
Fastd
Thanks for your response, comments on heat in the carb are noted.
Dashwill be Competition Style/Warner Guages/No Glovebox.
Heads will be aluminium for sure to keep front end weight down.
Regards
David
