Old 05-26-2018, 08:21 PM
Hoodabest Hoodabest is offline
Send a message via AIM to Hoodabest
Originally Posted by LMH View Post
All 351W that are externally balanced, use a 28oz weight. Make sure the front balancer matches.
Thanks Larry, I'm on the hunt for a flywheel now.
The seller claims that the heads are maxed out for flow in factory castings. He was running an iron 4 bbl intake, I'll be replacing that.
I have a Price dual quad manifold topped with 390 holleys. Will it work well with this setup? Or should I look for a single carb combo?
Current plan is to continue the 408w build, so I'll also need an intake there too.
