  #45 (permalink)
Old 05-27-2018, 02:29 PM
DanEC's Avatar
DanEC DanEC is offline
Congratulations Dan, looks great! I recall that Dan Williams instructed me to put some cheap 80-90 weight oil in my new top loader and then take it for a couple of slow laps around the track making sure to not exceed 4,000 rpms and then drain the oil and fill with a high quality 80-90. The idea was to flush out the packing grease and remove any metal pieces as the new gears mesh.
Hope everything goes well. Saw your other posting and do not have anything to suggest regarding the spring.
Jim
Thanks, I will probably do something along those lines. It's pretty easy to drain and fill the Toploader due to the drain plug. Interestingly, I still found assembly lube traces inside the cluster gear roller area and in the input roller bearing area. That stuff hangs on.
ERA 782 Running
