  #29 (permalink)
Old 06-02-2018, 12:39 PM
DanEC's Avatar
DanEC DanEC is offline
Well, from the outside it looks perfect....
It looks even better now.
I'm going to say the TO Bearing is self aligning. The inner race has about 1/16 inch, maybe a bit more, lateral play which seems to make no difference in spinning effort or smoothness.
When I pulled out the TO Bearing and I quickly discovered that it would not be a good idea to get carried away with a grease gun lubing these things. When I pulled it out it was well coated/gunked up with grease that had worked it's way out of the race. Fortunately it seems to be a pretty stiff, high temp grease so although it go flung around inside the bellhousing a little, it just stuck and didn't run anywhere. Wiped it down, gave it a very, very light shot of fresh grease and put it back in. Adjusted the clutch where I can push on the fork to bottom the slave and get a slight bit of play at the TO Bearing.
Unfortunately too hot to finish putting the interior back in today.
ERA 782 Running
