Old 06-06-2018, 02:00 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Suggest you look at moellermarine.com for their non-swing arm marine sending units.
Working on a vertical shaft the gauge does not show the great movements of a shifting fuel level due to changing levels from cornering and braking etc. Make sure your gauge works with a 240-33 Ohm sender or you will have to replace the gauge. They come in lengths that are in one inch increments and as I remember you want one that is one inch from the bottom of your tank for the proper length.
