Old 06-10-2018, 11:34 AM
tortuga tortuga is offline
Default Great Info!
Originally Posted by Gaz64 View Post
You can probably go down again on the mains, another 2, then up 1 if necessary, and also pull some accelerator pump volume out.
Those pink cams deliver a fair bit.
Cams from smallest to largest :
cam color #1 #2
white 17cc - 19.5cc
blue 18cc - 20cc
red 18.5cc - 20cc
orange 19cc - 24.5cc
black 19cc - 18cc
green 24cc - 30cc
pink 30cc - 37.5cc
Some of the cams, although smaller in total volume, are more aggressive in the first third, so take care in selecting a cam.
Troy Patterson from TMP Carbs knows all about building LARGE Holleys that can wide open at 1500 rpm. Not many can do that.
Not that anybody I know does, but shows what his carbs can do. He runs annulars on most of his carbs as a personal preference.
Once you've had annulars in a true tuned setup, you won't go back to anything else.
Thanks Gary!
printing this out for my man cave bulletin board.
Steve H
SPF 1764
