Thread: 48 IDA Help
Old 06-10-2018, 05:37 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
More details please.
What ignition system, advance curve would also be handy.
The pump inlet valve exhaust orifice size please, it is classed as a 00 if no orifice.
You might also be better with 40mm venturis if only street.
Yes, you need 3rd hole progression.
You probably need a whole setup change.
So a few more things needed here for info:
Carb Specs
42mm Venturi
120 Idle Jet Holder
70 F10 Idle Jet
Main Jet
F7 Emulsion Tube
Air Corrector
200 Needle Valve
50 Pump Jet
Pump exhaust
Gary
