Thread: 289 Plans Build
Old 06-10-2018, 08:56 PM
Three Peaks Three Peaks is offline
While you're trying to get other things done, you can rebuild the rear end with new clutches and once you get the uprights you can pull the hubs to be drilled and replace the hub bearings before replacing the hubs. Or have a shop do it. There are videos on youtube for the differential. It is pretty easy and you will be able to do it in a couple hours if you're handy.
