Old 06-13-2018, 06:17 AM
mofo mofo is offline
The tail of the transmission and the differential can be off a few degrees left to right, what is more important is that they are in the same plane up and down.
Jim, when you say in the same plane up and down, don't many vehicles especially higher clearance vehicles like trucks have a downward sloping rear drive shaft from transmission to rear diff? Is the same plane ideal but often not achieved?
Also, if I am using the tranny mount from CR, and a Ford 8.8 rear which is commonly used in these cars, and have 3.75" difference (tranny at 15.25", diff at 11.5") wouldnt mosts car builds end up in a similar predicament? I dont see any way to close that gap? Lowering the engine any more would have the bellhousing with limited ground clearance. Its at 8 inches now. So I could lower the engine 2, maybe 3", bellhousing would be at 5" ground clearance, and I would have to make some spacer bushings that drop the tranny mount the same amount. Have others done this? If I go much lower, my engine mounts and bolts would be down inside the frame rails. Dont have headers yet to see how they would be impacted.
Here is a sketch of where I am at currently:
