Thread: 289 Plans Build
Old 06-16-2018, 11:02 PM
Three Peaks Three Peaks is offline
Referring to the panels for the body for rivetting, you'll probably need .090 sheet aluminum for the pieces you need to make up templates for and shape. The inner fenders, rear wheel arches, trunk aluminum, cockpit, rear bulkhead, firewall, door surround pieces, radiator enclosure pieces, and a few other smaller pieces you'll need to form. Not sure what others used, but I found .120 was a bit too stout for a lot of these pieces. .120 also wanted to crack when bent 90 degrees or more in a brake. I'm thinking .062 would possibly be enough and I've heard of guys using .040 for some of these pieces.
David Kirkham has some articles on the "Kirkham Academy" on here or on the Kirkham site on tips on making the aluminum bodies, what alloy they use for the bodies and what thickness they use, tools they use for shaving down the joint welds, etc.... lots of great info if you're into rolling your own.
Bob
