  #35 (permalink)
Old 06-21-2018, 10:11 AM
Cobra #3170 Cobra #3170 is offline
Default Different Spec
Now, this is an area that is just slightly beyond my expertise, but you might consider going with a NAS 624/MS 21250 Series bolt (as per that two page PDF I just posted).
Certainly worth a try, I don't look forward to changing out those 16 fasteners every 4 months during the season. Thanks for the suggestion! I had a problem with steering arm bolts failing (Grade 8 from Air Craft Spruce) and switched to aerospace grade 160,000 psi bolts and it solved the problem, might work with halfshaft too.
