Thread: Stunning 289
Old 06-21-2018, 01:40 PM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
Originally Posted by HealeyRick View Post
This is truly a beautiful car. Are these the correct exhaust manifolds for a 289 Cobra? MORE NEW COBRA STUFF FROM HAWK I believe I had seen them before but they were not being reproduced.
Somebody on the west coast of the USA is making replacement iron Y manifolds also.
(AC Cars was the original supplier of all the iron Y manifolds and fabricated exhaust system components including mufflers except chromium plated tail pipe tips. Small parts wise Dorman® provided studs for the down pipes, Shakeproof® provided the internal tooth lock washers for the iron manifold fixing twelve point cap screws, Ferry Cap & Set Screw Company® provided the twelve point cap screws to secure the iron manifolds, and Dunlop® supplied the vibration isolator mounts near the mufflers through a subsidiary.
The iron Y manifolds for Cobras are different than the ultra rare Ford offered ones for Ford Falcons. Very rare Sunbeam Tiger iron Y manifolds offer by Rootes were not the same as Cobra or Falcon versions.
Early AC Cars casting included their part number cast into each Y manifold. Most iron Y manifolds for Cobras have no text included.
All but cars near the end with 4V and all 2-4V induction systems required exhaust heated air for the automatic choke pull off system. Engine installers had to braze or electrically weld a for the purpose fitting to one Y manifold. A steel tube was inserted into that fitting and connected to the automatic choke mechanisms.)
Dan Case
