  #39 (permalink)
Old 06-21-2018, 08:08 PM
Cobra #3170 Cobra #3170 is offline
Default Half shaft bolts
Originally Posted by Morris View Post
This is the bolt we went to
NAS 624/MS 21250 SERIES: 12 POINT EXTERNAL WRENCHING BOLTS
These fine-threaded, twelve-point head bolts have a minimum tensile strength of 180,000 psi and a minimum shear strength of 108,000 psi. Thread length is consistent within each diameter and standard grips are in 1/8” increments beginning at 1/8”. These bolts also have a large radius between the bolt head and shank for additional strength. This requires the use of the MS 20002C series beveled washer under the head. A “Superbolt” for the most demanding applications. Please note that odd number grips, i.e. –15, –23, etc., are not standard and may not always be available. Please inquire for specifics.
Thanks Morris,
Using jet nuts but bolts are inferior to what you are using. Do you have a suggested source for the bolts and washers?
