Old 06-27-2018, 09:16 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Flat surfaces on housings, completely clean and dry, 1.5mm bead of RTV on both sides of each gasket, let set 10 minutes, assemble, torque bolts to 10lbft, LEAVE OVERNIGHT, refill with water first, water is cheap, all ok, drain out, and refill coolant, bleed system etc.
Gary
