Old 06-28-2018, 03:26 AM
Ron61's Avatar
Ron61 Ron61 is offline
I have had some trouble with spacers not being completely flat. Clean everything off very well, wipe it dry with alcohol or some non greasy cleaning agent and then put it on a completely flat surface and see if you can see any deviation at all in the area where the leak is. I used a wire brush to clean mine and there was a very tiny, almost impossible to see place that wasn't flat. But I made up for this as mine had an O ring groove so I used a slightly oversize O ring and gaskets which I put some sealer on and let set for a minute or so then put everything back on and torqued it down. I never had so much as a drip after that.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
