Old 06-28-2018, 04:34 AM
patrickt patrickt is offline
Originally Posted by zzmac View Post
Everything is brand new except for the billet spacer. The leak is coming from between the new housing and the spacer. The spacer doesn’t appear to have any cracks in it.
I know, but that doesn't mean it's any good. If everything is clean, plumb, flat, and not cracked then you can usually just use a homemade gasket, and tighten it down with a wrench and you're good to go. Try doing what Gaz wrote and, if that fails, then something is either warped or cracked, even if you think it isn't. That's the only possible answer.
