Old 06-28-2018, 01:13 PM
EM-0785's Avatar
EM-0785 EM-0785 is offline
Senior CC Premier Member
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
Originally Posted by EM-0785 View Post
While the last two answers likely summarize the help needed, here's a longshot just in case. Is one of the bolts bottoming out before fully sealing with intended torque. Aain, I wouldn't think that's it because that would seem to leak at both layers. Also, you'd likely notice that. And, also, if it was it could be due to uneven casting as mentioned above and may then be part of a joint solution of milling and right length bolt.
Best of luck! Brent
Here's another longshot just in case! Any chance the thermostat is upside down and of a design that such is not allowing full seating when torqued down?
Brent
