Old 06-28-2018, 05:31 PM
zzmac's Avatar
zzmac zzmac is offline
Cobra Make, Engine: Superformance, Roush 402R
The old t-housing was a Mr. Gasket I'm pretty sure and it was warped. I now have a new t-housing from Napa W2486 and it seems like a good one. No wobble but the jury is still out until I fix this leak. Bolts are brand new stainless steel and they aren't bottoming out and I'm using new S/S washers. Thermostat was put in last time correctly and I used some gasket sealant along with new FelPro gaskets and let it set for 1/2 hour.
Both times when I tried gasket sealant it leaked more and the last 3-4 attempts it leaked without engine running - no pressure.
At some point tomorrow I'll try again without a thermostat (just in case it moved) and if it still leaks then I'll try Gaz64's suggestion. If that doesn't work then I'll take the spacer back to the machine shop to make it perfect and start over. (grrr) lol
