Old 06-28-2018, 05:54 PM
tortuga tortuga is offline
I had to Dremel out the aluminum superformance spacer a bit (taper the inner shoulder) to ensure that the Tstat fit in there dead flush...checking without the Tstat would tell, but so would just fitting it and placing on a flat surface...I've fallen prey to the too long bolt scenario too, but you may take a look and make sure your Tstat is fitting all the way flush...
