Old 06-28-2018, 09:20 PM
Rebel1 Rebel1 is offline
Originally Posted by dave295 View Post
There's no feeling quite like re-inventing the wheel!
Rules and Regulations compliant?
Or have I missed something?
Dave
Dave, you'd need to talk to an engineer to ascertain compliance.
I understand because the Cooper calipers were listed as an approved Jaguar replacement in UK that they are acceptable.
I believe the Tenrocca option would be the lightest setup you could possibly achieve for track/performance work using Jaguar XJ6 suspension/brakes.
The Cooper calipers were made as an optional choice for Jaguar XJ6 restorers wanting a performance caliper. They copy the e-type alloy caliper but milled to suit XJ6 caliper mounting etc. According to Cooper's they weigh less than half the XJ6 cast iron calipers but I no longer have any cast iron calipers to compare.
As an indication of weight the Cooper Calipers fully fitted with S/S pistons, seals, pads, pins and retaining clips (ie ready to bolt to the Jag uprights) weigh 4.7Kg. They also utilize standard jaguar parts so maintenance is a breeze.
