Thread: New Build
Old 06-29-2018, 10:58 PM
Dominik's Avatar
Dominik Dominik is offline
Default header gasket
If you like advise on header mounting, read on. If not ignore me :-)
Think flanges, 3/8" - done
individual header pipes - done
Studs with ARP serrated nuts - almost done ;-)
No fixed connection to collector/sidepipe to keep the vibrations away - done
No gasket! (worked for me)
This way the flanges sit from day one. May not work if your sidepipes are very restrictive
To fit the sidepipes once the header pipes take a set, and may warp a bit, I let 3 of 4 loose, slide them into the collector and tighten the primaries. This is when no gasket helps. I also had the slip-in length slighlty different so that one after another can be pushed in.
If I don't respond anymore, that's because I can't log in
