Old 07-02-2018, 08:08 AM
RedHawk's Avatar
RedHawk RedHawk is offline
I have a gauge on the reg and it is set to 7. TORQSTORM rec 6-8. The reg uses 7 as a base and then adjusts as needed. The vacuum seems okay too as it idles pretty good. I can check that later today. Thanks for the tips.
Originally Posted by Gaz64 View Post
I would think about adding a fuel pressure gauge, just for testing, in the cabin.
The reg could be referenced to the hat, so fuel pressure would be say 6 at idle, to 12 under boost.
Where as to manifold vac, it would be say 3 at idle, 6 at zero vacuum, and then 12 etc.
Depends on your current vacuum at idle, (camshaft), and how much boost you are running.
You could also reference the regulator T'eed with an adjustable bleed to the carb hat, then can you dial up what your fuel pressure curve is separately to boost.
Gary
