Old 07-02-2018, 04:50 PM
PNJSNAK's Avatar
PNJSNAK PNJSNAK is offline
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Yes, but if I recall (been 18 years) there is no easy way to do it with the bracket mounted usin a standard drill.
I think I first drilled a hole thru the bracket and matt material mounted the bracket transferred the hole position. Removed the bracket and then drilled the hole.
Then mounted the bracket and then bolted together.
One thing, don’t forget to lift the body slightly to put a little stress on the body per the instructions.
OhioCobraClub.com
