Old 07-03-2018, 06:35 AM
tortuga tortuga is offline
Default Everything but the spindles...
Originally Posted by Apex_speed View Post
Did you do the suspension as well or just the bars?
Also, I assume you have the R/T rear suspension mounts. I just put them on a 2,000 mile car with the upgraded 10MM bolts and found that both sides had sagged 5MM on the stock mounts. Pretty scary stuff!
Got his coil over set, front ball joints (probably the biggest improvement), rear upper mounts (SPF as you indicated are junk), rear upper a arm heim, and gen 3 bar set; everything from the Cobra Vally suspension catalogue short of the front spindles I think...car rides and handles much better than It did stock...
Steve H
1764
Superformance 1764
Built 427W
Aiken SC USA
