  #32 (permalink)
Old 07-09-2018, 08:52 PM
big deuce's Avatar
big deuce big deuce is offline
Originally Posted by CompClassics View Post
An old drag racers trick is to apply a slight vacuum to the crankcase by installing EGR valves, one way check valves, into the collector area of the header on each side and attach a hose between them and a fitting on each valve cover or a crankcase breather. The Exhaust pulses create a suction which in turn cause a slight vacuum within the crankcase, drag racers looked at it as free horsepower as the pistons were having to pressurize the crankcase when heading to BDC.
Very true, and way more effective on larger cubic inch engines. Dad and I built an off topic 505 bbc for our drag car and used that exact setup; until we had it dyno'd. The machine shop said, " lets put a evac pump on the crankcase", threw a moroso evac pump on and hp went from 790 to 820hp with no other changes. Oil pressure was rock solid also, not so much without the evac.
