Old 07-10-2018, 05:55 PM
CoyoteCobra CoyoteCobra is offline
Cobra Make, Engine: A&C, 2nd gen 5.0 Coyote, XAct Cromo light flywheel, TR3650, 3.25:1 LSD
Thank you for sharing some details on your build.
Before getting the Coyote I spoke to Joe and he mentioned that the Coyote build was rare.
The Coyote is quite wide. Today I sat the engine/trans assembly down on blocks in between the frame rails to see how things are going to work out. I roughly positioned it where it should go and it looks like it is going to be really close. This was just a quick mock up, but the front timing cover is going to be the tightest spot and has about 0.5" on each side. I'm hopeful that I will be able to get away without making major modifications to the frame.
I'm sure I will run into plenty of snags and appreciate the advice and tips shared by others.
