Old 07-12-2018, 12:32 PM
Large Arbor Large Arbor is offline
Cobra Make, Engine: ERA 714
I believe I am running the same setup without the plate as the Bellhousing has the space built in. Is there any way the clutch fork got bent or could be bent to provide clearance? It seems there was a little spacer under the hinge portion that could be removed, but I may be wrong on that. I will have to look on Friday at my set up.
Phil
