Old 07-14-2018, 10:26 AM
Apex_speed's Avatar
Apex_speed Apex_speed is offline
Cobra Make, Engine: Superformance Mk3 with Roush 427R
Originally Posted by Jim Vander Wal View Post
Apex,
The bolt in CV is for the newer style center, cars in the #2500++ range. You would be correct if the diff was the newer style.
#1764 as indicated by Tortuga uses the late '80's Super Coupe IRS, this was also used in the one or two Mustang IRS cars pre the 2015 change. The CV buckets push in and are held by a retaining clip inside the diff, not bolts. Prying the bucket out is the normal procedure.
Jim
Former owner of SPF 1855 & 2584
Good to know. Bolt on inners also are present on cars built with the Dana from the ‘04-‘06 GTO like mine but did not know what car numbers those covered. I know nothing about the earlier cars. The Dana has retaining clips as well so you can take the CV out with the output flange attached but I generally wouldn’t.
