Old 07-17-2018, 12:20 PM
eschaider's Avatar
Originally Posted by AC Ventura View Post
I agree, except that I rang Powermaster Technical and they said 70% is ideal as it enables the pinion to fire back easily.
Can't say I agree with that at all. Especially turning over a big block.
So machine 1/16" off the front of the starter flange? Don't really want another $500 flywheel....
All of my Ford service manuals for FEs call for complete forward/back engagement on the ring gear and the depth must be greater than 1/2 of the ring gear tooth depth, as per the pics from this service manual below.
Patrickt is steering you in the right direction. I might consider having the material removed from the flywheel register that bolts to the crank. If you do it that way you kill two birds with one stone — you get proper starter pinion engagement with the flywheel and you also improve your TOB and clutch release arm clearance to the BH.
Ed
