Old 07-18-2018, 05:59 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
If I may, on my 48s I found two very critical things that needed attention.
1. linkage - your linkage can look great, but function poorly. Make sure it will repeat and travel WITHOUT BINDING.
2. Position - make sure the throttle rests at the same point each pedal let-off and make sure it gives you FULL THROTTLE when the pedal is all the way down.
I offer these as checks to assist in your setup.
I hope this helps - I did not read all of the comments as it was clear there are several ways to do this.
Tru
