Old 07-19-2018, 05:40 PM
bubela bubela is offline
Cobra Make, Engine: Backdraft w/Smeding 351 dart block punched to "427"
Looks like you have an e36 M3 set up from the 95 to 99 3 series. Appears you have a 188 mm ring gear/diff in there. I'm on a turbo BMW forum and a lot guys have problems (even with the DSS stuff) on that size differential. Need to step up to the older seven series differential. (Big bucks, especially if Dan from Diffsonline gets you one. =) Have you broken another stub or just the one so far?
I wonder if Backdraft has moved to the e46 (2001-2006 M3) set up. Everything is stronger. My 425wtq BMW is running stuff from the e36/e30 generation. My 545wtq car is using the e46 M3 rear without any issues.
#663 Backdraft Smeding "427" 6spd
www.prussianmotors.com
