Old 07-19-2018, 07:22 PM
CoyoteCobra CoyoteCobra is offline
Cobra Make, Engine: A&C, 2nd gen 5.0 Coyote, XAct Cromo light flywheel, TR3650, 3.25:1 LSD
I will be sure to post pictures and explain my build as it progresses. My A&C build is probably a bit different since I'm using a Coyote. If there are lessons I learn during the build and parts that work to make the coyote fit, it would certainly make sense to share for others to consider during theirs.
Recently I assembled the Wilwood DynaLite front brakes, and I used Summit disk brakes for the rear. I finished bending and running most of my brake lines, and plan on sitting the body on the frame with the engine in place soon. By the measurements I made so far, the clearance with the foot boxes, headers, frame, and hood are going to make for some tight spaces.
I also need to order wheels and tires soon for the body placement. I'm still researching what sort of back spacing and offset others have run without significant rub.
