Thread: Hi.
Old 07-26-2018, 06:10 AM
EM-0785's Avatar
EM-0785 EM-0785 is offline
Senior CC Premier Member
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
Originally Posted by t walgamuth View Post
Thanks EM... that covers a couple of things I have not ever thought about before. I'll be replacing the other MC soon so both will be new. so that should take care of the problem. There does not appear to be any leaking around the calipers so they should not be the problem.
You bet, like I said, if it helps, it was from someone else and seemed to make some sense! Another possible area for fluid loss, which happened to me (but you'd likely have seen the fluid build up).
The old rubber master cap seals were in very rough shape and not sealing well. On steep hills and in heavy braking they actually leaked fluid. I replaced them and that stopped. I haven't yet replaced the masters as I'm considering longer term pedal and floorbox options/arrangements, but those are holding firm now.
Brent
