Old 08-03-2018, 05:18 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
So either the oil passage is blocked/restricted, or the bearing outer edge is to close to the crank fillet restricting the oil flow leaving the bearing, or the bearing crush was insufficient.
Many guys does not measure bearing crush, it is what holds the bearing in the rod.
Now you need a full engine rebuild.
Gary
