Old 08-09-2018, 11:57 AM
CompClassics's Avatar
CompClassics CompClassics is offline
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
You need to ad the resistor to the circuit to have the system work correctly. Since you do not have the resistor, leave that part of the circuit out and see if the charging system works correctly for the amp gauge circuit only. If that works correctly then ad the indicator light part of the circuit.
